3 subs, which amp?
Old 09-15-2008, 09:23 AM
  #21
blueflamed03's Avatar
Originally Posted by Pewter53
higher end digital audio amps which are made by audiobahn are very good amps
Old 09-15-2008, 09:25 AM
  #22
Originally Posted by lo&sloSierra
ok well now i got 4 subs, 2ohm ones and they are comp 10's the new ones, just the single voice coil(due to mounting depth) i have 2 behind the seat and 2 in the center console, which amp do i need to get a hold of?
Kicker Comps only come in SVC 4 and 8 ohm...
Old 09-17-2008, 09:02 PM
  #23
lo&sloSierra's Avatar
well damn, my box says 2 ohm, they can be wired up though to run at a 2 ohm load right?
Old 09-17-2008, 09:07 PM
  #24
son of a bit*h when i bought my other 2 speakers (comp 10's) they were sent in a cvr box, damn so i have 2 of them wired up right now in the back and they are the 4ohm speakers and they are on a 400.1 and they are running at a 4 ohm load i guess?
Old 09-18-2008, 08:22 AM
  #25
should be like this is both are 4 ohm.
Old 09-18-2008, 07:14 PM
  #26
sweet man thanks i appreciate it
Old 09-18-2008, 09:52 PM
  #27
Originally Posted by blueflamed03
im not talking about there intro series they have some high end amps available if you will call them and they will even make it 18 volt compatible.
Old 09-19-2008, 08:53 AM
  #28
changing, or modding an amp to handle over 15.7v is a pretty simple process, in which some can do one they know what resistor to pull. Plus, on normal cars, having an amp that can 'handle' 18v does no good, unless you can GIVE and feed 18v.
I've never been impressed with any amps Audiobahn has made.
Old 09-19-2008, 11:02 AM
  #29
me either until latley but who cares i was just giving him some ideas and like i said the mmats amp is better than any kicker out there.
Old 09-19-2008, 01:56 PM
  #30
we all have opinions, you like Audiobahn too...I prefer not too
Quick Reply: 3 subs, which amp?
