Adding OEM fog lights to 00-02 truck
I have done countless searches, unfortunately - lots of dead ends. I see that the BCM requires flashing, but can't find anyone to do that operation. My 2001 did not come with them, despite have most other options: keyless, power windows & locks, power seats, overhead console, etc. I pulled the complete headlight harness and switch from my wrecked 2000. I also installed the BCM and PCM from that truck into mine in an attempt to get it all to play nicely.
I'm about ready to bypass some of the factory wiring and just hard wire between the fog lights and factory switch. Has anyone done this? Links to good wiring diagrams detailing this?
TIA
TIA
At the very least you would probably want to trigger a relay from the factory switch, it likely isn't rated for any decent amperage draw because it typically sends the switch connection to BCM which will be low amp.
I don't know if that switch would even be very easy to modify, I believe it's like a momentary switch? and doesn't actually click in/out like a make/break connection.
less than ideal from a functionality standpoint, but it keeps the OEM switch! And I hate drilling factory plastics 🤷♀️
Bluecollar Hotrods (12-23-2023)
My 99 Silverado didn't come with fog lights either. I'd like to add them too. I replaced the BCM because my last one fried, but did pay attention to see if the donor truck from the junkyard had fog lights. 🤔
Looks like the programing is just a matter of selecting the correct file when programming the BCM.
https://www.youtube.com/watch?v=pgNx...partanAutoworx
The 99-02 kit was GM# 12495928
https://www.performancetrucks.net/fo...ts-nbs-521646/
I recall it coming with the harness, the lamps, and the switch. The only image's I can find are on what looks to be a Russian site though...
