Adding OEM fog lights to 00-02 truck
Old 12-25-2023 | 03:06 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Originally Posted by Bluecollar Hotrods
I saw their videos on YouTube, but go to their website - they no longer offer BCM programming for 99-02. 🙄 My girlfriend's father likely has a Tech2, maybe I can bribe him to help me reprogram the BCM.
I have both but I dont have the plug for the BCM side of my bench harness.
Did you check the fuse box on your truck? I believe you have to add a 15 amp fuse in a certain spot on the fuse box based on what I read and saw.
Bluecollar Hotrods (12-25-2023)
Old 12-25-2023 | 05:18 PM
10 Second Club
Yes, I stole that fuse, the switch, and the entire front headlight harness from the donor truck. When I did the Z71 front valence, I added new fog lamps.
1FastBrick (12-25-2023)
Old 12-25-2023 | 09:17 PM
1FastBrick's Avatar
So the 2000 BCM didn't fix the issue in the 2001 truck? did it cause any lights or communication codes?
I only know on the 99-00 there are some minor differences in the wiring on the engine Vs. the 01-02. Some of the Programing is different as well. Maybe some of that translated into the BCM programming as well?
Old 12-26-2023 | 08:47 AM
10 Second Club
My dome light and overhead console lights haven't worked since. However, I redid the headliner at the same time. I need to get unlazy and pull it back down to see if everything is plugged in. It's tough driving it daily and trying to work on it. When I have fee time,I find myself making it faster vs. fixing all the little things that bug me. I need to finish the rehab on my 2500HD and take this truck off of the road for 6 months to go over everything.
Old 12-26-2023 | 08:29 PM
1FastBrick's Avatar
I looked up the 99-02 BCM attachment for the bench harness I have and boy are they proud of it... would have to get a BCM Pigtail somewhere and make one.
Old 01-03-2024 | 08:20 AM
SimpleGreen's Avatar
It must be a luck of the draw ordeal. I swapped in factory fog lights to my 2005 some years back using the GM kit and it worked fine with no programming. I just pinned in the harness to the under hood fuse block, changed out the cargo lamp switch inside the dash and was good to go.
Old 01-03-2024 | 06:52 PM
10 Second Club
Is this something that could be scavenged from a junkyard vehicle?
Old 01-03-2024 | 06:54 PM
10 Second Club
03+ they don't run through the BCM. But the power window switches do. Ask me how I know. 😡
SimpleGreen (01-03-2024)
Old 01-04-2024 | 01:42 AM
1FastBrick's Avatar
The BCM plug that provides the power and communication could be scavenged from a junkyard.
Bluecollar Hotrods (01-04-2024)
Old 01-04-2024 | 04:29 AM
10 Second Club
Next time I'm in the local salvage yard, I'll grab on if you want one. They tend to not charge me for small items like that.
The following 2 users liked this post by Bluecollar Hotrods:
1FastBrick (01-05-2024), silentbravo (01-04-2024)
Quick Reply: Adding OEM fog lights to 00-02 truck
