Adding OEM fog lights to 00-02 truck
Did you check the fuse box on your truck? I believe you have to add a 15 amp fuse in a certain spot on the fuse box based on what I read and saw.
Bluecollar Hotrods (12-25-2023)
Yes, I stole that fuse, the switch, and the entire front headlight harness from the donor truck. When I did the Z71 front valence, I added new fog lamps.
1FastBrick (12-25-2023)
I only know on the 99-00 there are some minor differences in the wiring on the engine Vs. the 01-02. Some of the Programing is different as well. Maybe some of that translated into the BCM programming as well?
So the 2000 BCM didn't fix the issue in the 2001 truck? did it cause any lights or communication codes?
It must be a luck of the draw ordeal. I swapped in factory fog lights to my 2005 some years back using the GM kit and it worked fine with no programming. I just pinned in the harness to the under hood fuse block, changed out the cargo lamp switch inside the dash and was good to go.
03+ they don't run through the BCM. But the power window switches do. Ask me how I know. 😡
SimpleGreen (01-03-2024)
Bluecollar Hotrods (01-04-2024)
The following 2 users liked this post by Bluecollar Hotrods:
1FastBrick (01-05-2024),
silentbravo (01-04-2024)
