aeroforce gauge question??
I've been looking at buying the aeroforce gauge and was wondering if it can be used as a boost gauge as well, what about fuel pressure or even a afr wideband? Pat.
I have an older one, but the new ones have analog outputs, so they can read a WB and a FP guage. I also believe they can be programed while using a 2 or 3bar MAP so they will read boost.
High on diesel fumes
If I'm understanding 2004SSS and vanillagorilla correctly they are talking about adding an extra 2-bar MAP sensor somewhere and feeding it's output to the analog input of the Aeroforce gauge.
Your other option is to replace the stock MAP sensor with a 2 bar sensor and calibrate it in the truck's tune. Then you can read boost straight from the PCM.
GXPJAY
02-13-2022 08:15 AM
