Amp has power, but no sound from sub
1 Post
Like the title says
Was going to school the other day, not bumping it loud, and it cut out. I waited and it came back on playing, figured just the fuse under the hood wiggled loose. Well the sub kept cutting out, cutting out, and cutting out. I could lightly tough the cone of the sub and it would play again, but then cut out.
Is it the amp or the sub??? I already checked the connections on the amp and sub/box.
Oh and the power light for the amp IS on.
1 Post
That's me
Checked pretty much all my connection from the amp to the headunit and to the sub, pulled fuses and checked em. All seems well. Its something the place where i got it installed is doing, it would have to be. I haven't touched a single setting on the amp, just changed EQ type things on the headunit itself.
EDIT: If i get it replaced again, it will be my 4th sub. Bought and had everything installed on my B-day back in february. Every replacement has been free since the excelon units have a 2 year warranty.
1 Post
Amp is a KAC - X20, pushes 570 RMS. The Sub is a KFC-XW1200F, 1400 MAX and 350 RMS. Bought the amp big so i could get a second woofer if i wanted to later on. Amp is 2 channel. wiring for the sub comes straight off the amp to the box. As far as the amp wired to the stereo, no idea.
IDK what they are doing, but it is just costing them 200 bucks for every sub they hav to replace, and its just an inconvenience for me because i don't have time to get there before they close after i get off work.
1 Post
I DID notice a kinda burning smell this morning on the way to school. May have just been the heater running at full blast. Damn cold weather.
If i don't have time to run it up to the place i got it at tonight I'll pull the sub out of the box again and see if i can see anything on the woofer causing the problem.
I'm 99% sure now that the amp is NOT the problem.
