Body Control Module
Body Control Module
I have a 1999 GMC Sierra Ext Cab 5.3l.. Anyone happen to have the Connector Pin Diagram for the BCM?
A Schematic will work too..I'm trying to disable the damn auto-lock and I think if I clip the Speedo Signal wire that goes into it that will take care of it.
Schematics
C-1 Body Control Module
Connector Part Information
C-2 Body Control Module
C-3 Body Control Module
- 12160778
- 24 Way F Micro-Pack 100 Series (BRN)
Code:
Pin Wire Color Circuit No. Function A1 BLK 1850 Ground A2 ORN 1140 Fused Battery Feed A3 WHT 194 Power Door Lock Relay Feed - Unlock Coil A4 LT BLU 195 Power Door Lock Relay Feed - Lock Coil A5-A6 -- -- Not Used A7 BLK 755 Delayed Accessory Bus Relay Output Coil - ACC Relay (Uplevel) A8 DK BLU 1393 Interior Lamp Relay Output - Coil A9 BLK 28 Horn Relay Output - Coil A10 -- -- Not Used A11 LT GRN/BLK 592 Daytime Running Lamp Relay Output - Coil A12 LT GRN 1037 Serial Data Signal (Class 2) B1 BLK 1850 Ground B2 PNK 39 Fused Ignition 1 Feed B3 RED/WHT 812 Reference Voltage Feed - 12 Volt B4 ORN 461 Serial Data Signal B5 -- -- Not Used B6 LT BLU 14 LH Turn Signal Lamp Input B7 DK BLU 15 RH Turn Signal Lamp Input B8 -- -- Not Used B9 BRN 41 Fused Ignition 3 Output B10 LT BLU 1134 Park Brake Switch Signal B11 BLK/WHT 238 Seat Belt Switch Signal B12 LT BLU 553 Transmission Shift Select Switch Output
- 12110206
- 24 Way F Micro-Pack 100 Series (GRY)
Code:
Pin Wire Color Circuit No. Function A1 YEL 710 Serial Data Signal A2 ORN/BLK 1057 Sensor Return (Passlock) A3 GRY/BLK 690 Courtesy Lamp Relay Output (Coil) A4 LT GRN 1381 LCD Dimming Signal A5 WHT 1080 Park Lamp Relay Output (Coil) A6 -- -- Not Used A7 DK GRN/WHT 1317 Fog Lamp Relay Output (Coil) A8-A10 -- -- Not Used A11 WHT 352 Headlamp Relay Feed (Coil) A12 PPL/WHT 1382 LED Dimming Signal B1 DK GRN/WHT 817 Vehicle Speed Signal B2 -- -- Not Used B3 YEL 1836 Passlock Sensor Signal B4 -- -- Not Used B5 PPL 524 Headlamp Dimmer Switch Output (High Beam) B6 BRN 2409 Fused Interior Park Lamps Feed B7-B8 -- -- Not Used B9 LT GRN 80 Key Reminder Switch Signal B10 -- -- Not Used B11 DK BLU/WHT 727 Door Latch Switch Signal (Uplevel) B12 ORN 1732 Inadvertant Power Relay Status
- 12191375
- 16 Way F Micro-Pack 100 Series (PPL)
Code:
Pin Wire Color Circuit No. Function A1 DK BLU/WHT 149 Cargo Lamp Switch Input A2 DK BLU/WHT 1495 Courtesy Lamp Switch Output A3 BRN 1356 Flash to Pass Switch Signal A4 GRY 705 Reference Voltage Feed - 5 Volt A5 GRY 8 Instrument Panel Lamp Feed A6 WHT 278 Photocell Signal A7-B1 -- -- Not Used B2 ORN 54 Door Jamb Switch Signal - Passenger B2 LT GRN/BLK 394 Door Handle Switch Signal - LH Front (Uplevel) B3 LT GRN 262 Door Key Lock Cylinder Switch Signal - Driver (Uplevel) B4 TAN 126 Door Latch Switch Signal - LH Front B5 ORN 192 Fog Lamp Switch Input B6 PPL 328 Interior Lamp Defeat Switch Output B7-B8 -- -- Not Used
MA$TER_E
09-09-2015 04:14 PM
smokeshow
08-23-2015 09:23 PM
atxlt
07-21-2015 12:06 AM
