fosgate
i was hoping for some input on this setup for a 99 tahoe,
i was thinking about two 15" rockford fosgate punch stage 2's
a JBL GTO755.6 II amp
and i need some suggestions on what mids and highs get
apple bottom jeans
Unless you can get them for cheap, skip the RF's.
What is your price range for subs and what is that amp rated at?
Do you want to do components or stick with coaxials?
apple bottom jeans
That amp is not very powerful. 110 watts at 4 ohms is pretty bad even for a single subwoofer.
Sell that one and purchase a 1000 watt monoblock and a small 75x2 amp, and then you'll be in business for serious sound. You want two 15's so I bet your looking for loud.
these are the watts on the amp, kinda gibberish to me
117 Watts x 4 + 163 x 2 dynamic power
80 Watts x 4 + 150 Watts x 2 @ 2 ohms
60 Watts x 4 RMS + 107 Watts x 2 RMS@ 4 ohms
thats not gonna run 15's.....get a bigger amp!! rockford p2's should be around 250w RMS so a 500w RMS amp should do the trick.....
this one would work good for them......
http://www.onlinecarstereo.com/CarAu...roductID=18338
apple bottom jeans
Originally Posted by skellington
whats the purpose of the smaller amp if you got a 1000 watts
Amp for subs = 1000 watts
Amp for components = 75w x 2
Usually components need to be amped to get their full output. Since I don't know of any 4 channel amps that will push out 1000 watts on 2 channels and 75 watts on the other 2, your stuck buying two.
