hard wire rador detector 09 chevy
looking for ways to hard wire my detector so it comes on when i start the truck. any ideas?
Look for an accessories fuse in the fuse panel in the cab (if 09s have them). Then you can wire it in and have a protected circuit. Radar detectors have a very low draw so I wouldn't be afraid to put it on a circuit that was already used... Just not a vital one.
I used a fuse that was marked SEO ACC. This was in an 04 though. Your owner's manual should have some descriptions of the various protected circuits in the panel.
Grab a cig lighter extension and cut the male end off (the end you plug the radar detector into) and conect positive wire to a switched power source and the negative to ground. I generaly use the pink or orange wire in the ignition harness to do this and always use solder, never t-tap the ignition harness. I would also recommend putting a small fuse in the positive wire going tothe ignition wire, a 10A should be fine.
Thomas
Thomas
I hate my cats
Not an answer to your question, but drool over this. This guy is my hero.
http://www.youtube.com/watch?v=JxRLyiBs3XA
ARC
57
02-21-2022 10:54 AM
Corvette454l88
09-01-2016 01:24 AM
Fast86z
08-23-2015 12:35 AM
Nimoryan
07-05-2015 03:50 PM
