Help with audio setup for my 2005 Silverado Ext. Cab
#21
formerly 2004RST (changed 11/19/2012)
RE is HIGH quality (formerly known as US Amps) make sure you've got enough power to those bad boys...cause they'll take every little bit you throw at them...i would look into maybe sundown audio for an amp they're pretty solid with quality or you could always look at the RE XXX that should be enough
#24
Re audio
Looks awesome
If you google mmr audio and go to the first website there is a pic of my system. Its 4 re audio 8s in a 3 cube fiberglass ported box. Its about half way down in the middle of the page and its a white chevy ext cab. If you look into a box like this you can get alot more airspace. The box makes a big difference is sub performance. aeveryone on here is right about re audio they can handle alot of power. These 8s are rated at 175rms a piece and the get 300 from my amp and take it no problem.
85SS/85GN
07-22-2015 12:48 PM
atxlt
07-20-2015 11:06 PM
Suburban2500
07-19-2015 04:50 PM
