Hids??? Who sells good ones
#21
i just don't see how...i guarantee i put my DDM HID headlights through 100X more abuse than your grocery getters. literally i've sunk them in mud and water, got the bulbs wet, pressure washed the ballasts...for every 5 complaints that you see online there are 5k happy people. people only seem to talk about things when they are pissed off about a situation.
#22
#23
So when it comes to the HIDs, i talked to DDM on the phone, and the lady couldnt seem to answer my question. Is a 35 watt HID 9005 HB3 (high beam bulb) brighter than a 35 watt HID 9006 HB4(low beam bulb). I asked her and she just kept babling about a 55 watt kit, which i do not want due to heat issues. Can anybody chime in on this?
#24
Of course she would be confused, that isn't a fair comparison, you're talking about different lamps for different applications.
If you ask HID vs Halogen or 35w vs 55w, both being applied to the same lamp (bulb), you can now do a fair comparison.
In theory, both being powered by a 35w ballast and both being High Intensity Discharge, I would think those two lamps would be equally "bright" or produce the same amount of lumens. Although that may not be true, depending on the filament length, because they are different lamps for different applications. Not to mention, held in different shaped housing.
Edit: Which is a brighter, a 60W incandescent A19 lamp (normal bulb) or a 60W incandescent R30 lamp (flood light bulb)? Both are 60W and incandescent but shouldn't one be "brighter"? They put out the same amount of light but are designed for different applications and are held in different shaped housing....
#25
Its hard to beat DDM for the price, I have had them for use with little to no issues. But I am sick and tired of waiting forever to get them. It took almost a month for me to get the last set I ordered from them.
I switched to these guys. I put them in my fogs and I will see how long they last. I have heard pretty good things about them. They are a little more expensive but you dont have to wait forever to get them.
HID Kits Xenon Lights & LEDs | Xenon Supply
#27
#28
So I'm under the impression that the style of bulb, weather it low or high beam, the lumens are the same output. Both being a 35 watt HID 5000k for example. Just that the bulbs are made for a specific light housing. Halogen low beams are a 55 watt bulb where as the high beams are 65 watt. Thus producing a little more light. But they seem much brighter because of how the housing and reflector are shaped to direction the beam?
Typically you would choose a lamp according to its base, or how it installs.
#29
The amount of usable light also depends highly on the housing, its shape, quality, and clarity. My gut tells me that the different bulb types will have the same brightness. I've used DDM H7, 9006, and 9005, the bulbs were identical except for the base where they attach to the housing. Just get the same wattage and temp to make sure the color is correct. Also keep in mind that 55W will tend to wash out the color more than 35W. So a 35W 6000K will be bluer than a 55W 6000K.
#30
Found the thread for your reading enjoyment....
http://www.ls1truck.com/forums/shops...erience-2.html
