JL Clean Sweep
#23
Originally Posted by diehardchevy
What happened blown?
The OEM-1 works well, but I just dont get the warm fuzzy from the sound. I spend about 2.5 hours out of the day in my truck, and I am VERY pickey about the quality of the stereo. Believe it or not I think the Bose is great!
#24
Originally Posted by F8L Z71
7) CleanSweep™ includes a good-old-fashioned **** with stops at both ends to control the master system volume (at the outputs of the processor unit) for both the OEM and auxiliary sources. The master volume eliminates the effects of any OEM equalization that is dependent on the OEM volume control position and allows a high signal-to-noise ratio to be maintained in the system. When pressed, the master volume **** also selects between the OEM and Auxiliary source.
A dash-mountable status LED changes color to indicate OEM or AUX input modes. These small controls can be easily mounted in the cockpit within reach of the driver, wherever the installer and owner select.
#25
tdrumm perfectly explained my only complaint about the OEM-1.
Sorry you didn't like it man.
#26
hey i am right there with ya on the bose thing man! i love the bose as well.
Its all good man, it works for what it does.....just does not meet my taste. I know the clean sweep is about 10 times as much as the OEM-1 in cost alone.
#27
unsure if he still has it but he says that he will sell it for $275 brand new. i know that they usually go for around $350.
http://www.fullsizechevy.com/forums/...32#post1903832
But you got the oem-1 in and it at least worked for ya right?
#28
got it and it worked......
checking link now.
