JL's not hitting the low lows :( input??
On the 2nd diagram the wires from the positive and negative are like seen.
I wired it slightly different
I ran the negatives together in between the subs and ran the positive together in between the subs.
The farthest sub from the amp (passenger side) has the negative wire running to the amp
The closest sub to the amp (driver side) has the positive wire running to the amp
A web site said this was 1ohm another said it was 2 ohm
No, that would be with 2 ohm speakers, you said you have 4 ohm. The lowest you can achieve with svc 4 ohm speakers, would be 2 ohm. Right now your running 8 ohm. What you want is run + to + and - to -, then + and - from one speaker to the amp, and this will put you at 2 ohm. That's the lowest you can go with those subs.
Like this
[IMG][/IMG]
it can be confusing. And what size speaker wire are you running? You want bigger than standard speaker wire for that amperage, I'd say like a 12ga speaker wire, good luck, hope I helped.
Like this
[IMG][/IMG]
I am running 10 gauge wire. Yes the are svc 4 ohm subs
I'm glad I did not crank them didnt even make it through 1 song. They shut on and off. Checked all the wires and everything was perfect. So I disconnected all of it. I knew that should not be happening. I don't think anything got hurt they have run cold for max of 2-3min at low volume.
+to+ and -to- then + and- too the amp. Like
I'm going to wire them that way again. I started to realize after researching, parallel circuits is how to gain maximum efficiency and reduce ohms by half. I just created a horrible series with 4ohm speakers. The 2 ohm speakers will parallel down to a 1 ohm verses the 4 ohm speakers can only go down to a 2 ohm.
The best sealed size of box from JL specifications is .625 ft^3
My box is .85 ft^3 without sub or driver displacement. I should be slightly above/below the .625^3 ft. Plus the polyfill. I don't think it is the size of the box hurting the lows
It could be JL in a sealed box cant hit the lows b/c they are small 10"s
The settings on the alpine head unit are set for heavy bass
The amp
gain is at 6-7ish
db is at 8ish
fq around 120 hz
^About as far as I will push the amp. Way to loud for me haha but still no low lows that you feel just kinda hear the sub trying
The amp
gain is at 6-7ish
db is at 8ish
fq around 120 hz
Ya, I don't know too much about the jl's, but I don't think it's the box at all, because I have some Memphis 10's in a down fire in a under the seat box, and it hits the lows hard, but they are also dvc @ 1ohm. I would put them up against 12's all day.
