JL's not hitting the low lows :( input??
Old 02-18-2013, 09:17 PM
  #21
Camin00's Avatar
The amp wasn't hot but I know it has the self shut off feature.
My buddy has 2 10" w1s in a ported box, avalanche. They hit so hard with rap (just strait dominates my system) but dose not hit the mid/high bass with country, rock, metal, dub as well as my set up. Not as loud and a lot more sluggish. I guess that is all due to the port vs. sealed idea
Old 02-18-2013, 10:05 PM
  #22
dmelvin's Avatar
Correct. Ported boxes give up accuracy for deeper louder bass, and sealed is better for tight mid and high bass, there is a asterisk here though, because a ported box can be tuned for about any kind of music. It really depends on what music you listen to that will determine your box type.
Do you happen to know your amp make and model number so we can look up the specs on it and see what ohm load it's stable at, the RMS wattage, and the frequency response?
EDIT: Re-read first post.
Your amplifier is 2ohm stable. Which is where you'll get your best wattage and sound.
If your speakers are 4ohm SVC, then you will connect amp + to each sub + and amp - to each sub -. This will create a 2 ohm load on the amplifier, and give you 1000W RMS. If your subs end up being 2ohm SVC, this will create a 1ohm load and cause problems with your amp. With a 4ohm load you'll see 600W RMS, which is still more than enough for those 2 10's.
Old 02-20-2013, 05:09 AM
  #23
Sc00by's Avatar
What headunit are you using? Factory? Or aftermarket? Before I installed my stereo I used the outputs for the factory Bose sub and didn't have any lows because of the Bose crossover points used in their factory amps.
Posting this from my phone. Sorry for not going in more detail.
flatblack83
03-28-2021 10:28 AM
gaps
10-15-2015 02:53 PM
hackrst
09-02-2015 05:27 PM
TX Tahoe Z71
08-07-2015 03:58 AM
Aboss
07-09-2015 10:28 AM
Quick Reply: JL's not hitting the low lows :( input??
