My Fuse Holder is melting and I dont know why
OK my subs went out about a week ago i figured out that my amp wasnt getting any power at all so i opened the hood to look at the fuse and found that half of the plastic fuse holder was completely melted..so i purchased a new one, installed it and low and behold it started melting again whats going on???
apple bottom jeans
If the power wire was grounding out to the body, the fuse wouldn't stay around long enough to melt the holder, it would just blow..or he has a **** *** fuse holder.
FormerVendor
Melting fuse holder
It's basically this. You are running more amperage through the wire than it should normally handle. Sounds like you may have too high a rated fuse for the wire gauge. You need to look at all the components that are fed by the fused wire. What is the total amperage draw? You need to be sure your wire gauge and fuse are adequate to handle that draw. All electrical components will be labeled with their amp draw. Or at least it will be included in the instructions. But it's a good bet there is a label on each device showing amp draw. I couldn't find a quick and easy chart showing what wire gauge/fuse you need. PM me with the total amp draw and I'll get you the info. And YES..... It is important to check all grounds. They will also cause problems of all sorts.
dantheman1540
02-24-2016 09:56 PM
Vortec350ss
01-12-2016 10:36 PM
