My lights dim terribly when my bass hits???
Old 03-23-2007, 07:41 AM
  #21
Originally Posted by 9GMC9
Almost but no. Get a cap if you have a H.O. alternator. DO YOUR lights dim all the time or just on idle? If it dims all around no matter what, a bigger alternator will help.
Yeah the lights dim all the time instead of just at idle.
The speakers are a Kicker Comp VR 10 inch. I'm not sure of the model numbers
And I'll post the Amp model as soon as I install the new 140amp alternator.
Old 03-23-2007, 11:14 AM
  #22
wayland1985's Avatar
Well, if you got the alternator (An H/O alternator would have been better, IMO), add any 1000cca battery to the truck, and upgrade the ground straps/cable, and you shouldn't have any problems. Skip the cap altogether, it's only a band-aid for the problem.
Old 03-23-2007, 11:20 AM
  #23
High on diesel fumes
thunder550's Avatar
That will help, but I still think there's either a wiring or setup issue. That's a bit excessive for a 300 watt amp.
Old 03-23-2007, 12:12 PM
  #24
krambo's Avatar
O.K. Guys, Speaking from years of professional experience, SPL world records, and national champion dB Drag competitor:
Caps are good for paperweights and "Ohh - Ahhs" in a SPL system. The only benifit I see in them (no matter what capacitance they have) is to filter out A/C ripple from your alt. They add tremendous resistance to your audio electrical system.
Your amps: Do they have a regulated power supply? If they do not, you are wasting your time trying to supply them with more current. Gain, adjusting you "gain" isn't going to resolve your issue to a degree. I see someone mentioning "clipping" which is a correct statement however if you are running a low pass filter on your signal input, clipping your signal will be minimal (depending on the slope of the X-over). Often a gain will be too high and just cause unnecessary signal boost and noise.
Your electrical system needs to be looked at and her are some general rules:
1. Use high quality stranded copper wire for power and ground. Based on your power levels, I would suggest 4AWG wire. Keep your grounds short (less than 18 inches). Take your head unit ground wire out of the wire harness and ground it directly to your "firewall". Do the "big 3" upgrade.
2. Get a larger bank of batteries, either larger reserve amps or dual batteries. Your alternator is marginal at best and a nice 160 amp would do wonders. I wouldn't waste your time on an adjustable voltage regulator at this time unless you want to do a dedicated higher current line for a winch or something like that.
Old 03-23-2007, 01:26 PM
  #25
spitfire2332's Avatar
yeah, once again, all of these suggestions are OVERKILL for a damn 300 watt amp. Either something is going bad or its setup wrong, simple as that. Theres no need for a cap, no need for the big 3, no need for a HO alternator IMO.
Old 03-23-2007, 02:40 PM
  #26
Thanx guys...this is all great info...I'll check it more in depth this weekend.
Old 03-24-2007, 08:55 PM
  #27
tim_ramsey99's Avatar
u got a bad cell in ur battary and check ur alternator.
Old 03-24-2007, 09:13 PM
  #28
SmokedSierra01's Avatar
After 3 pages of discussion and this is your advice
I agree with you 100%. Like I said previously caps are just another way for the audio shops to make money when you put in a "high powered" system. I can't remember if you said it but NEVER ground your amp directly to your battery. One piece of advice is to make ALL of your connections as short as possible. LOW GUAGE WIRES + SHORT DISTANCE CONNECTIONS = BEST SOUND QUALITY, PERIOD. When you mount your amp, get under the capet and dremel off all of the paint to bare metal. After you have a good metal surface, drill and connect your ground. You don't need dual batteries, just put in the new alternator and change up your wiring.
What kind of truck do you have torque_wrench?
Old 03-24-2007, 09:44 PM
  #29
cpelton's Avatar
definately alternator... im running a 1000 mono alpine digital amp and two 10's with no other upgrades to grounds etc. my lights hardly dim at idle under full volume
Old 03-26-2007, 10:01 AM
  #30
Guys...again I want to thank you all for your input! This past weekend, I installed my new alternator and new battery and I went with the 100 CCA battery and a 140 amp alternator.
After the install my lights don't dim at all...and everything works perfectly.
Thanx gusy...I coulden't have fixed this without your advice!
Quick Reply: My lights dim terribly when my bass hits???
