Needing Some Insight On Wiring
Old 05-26-2012, 01:09 PM
dmelvin's Avatar
As far as fuse sizing. That depends on how much current you're going to draw, and how big of wire you're using. If your ballsts are 35W each (I'm assuming 2 for 70W total), then 70/12 = 5.8Amps of draw.
The equasion is Total Wattage divided by voltage = Amperage. A 10A fuse will work for you fine, I would also suggest 12ga wire, not because smaller wire can't handle 6 amps of draw, but the smaller wire you use, the more voltage is lost in the wire between your power source and the end point. When your voltage drops, the amps required increase.
Say you only have 10V at the light because you used something like 18ga wire.
70/10 = 7A of draw and so on.
Old 05-26-2012, 06:02 PM
SampsonSimpsonZ's Avatar
On the backside of the fuse box there's relays for lights and turn signals and wnatnot. I can't say exactly what all tht is what truck are you workin on
07 NNBS Silverado
Thanks for the replies
Old 05-27-2012, 08:34 AM
jbancs's Avatar
Originally Posted by SampsonSimpsonZ
07 NNBS Silverado
I know on that lower section has RAP power, on the top post, so I'm guessing someone used that as a source for switched power, the other two..your guess is as good as mine. As far as relays, even though it's already been covered, they're immensely useful for many situations. I mainly use them to increase amperage, switch polarity, and isolate circuits, but you can do pretty much anything you can with a switch, and more when using multiple relays.
ZONES89RS
21
09-24-2015 05:58 PM
pupi305
08-13-2015 03:48 PM
Bluecollar Hotrods
07-16-2015 08:52 PM
Aboss
07-09-2015 10:28 AM
Quick Reply: Needing Some Insight On Wiring
