new box for the hoe
#31
Originally Posted by Snake Eater
I'll draw it up and scan it to you.
#32
ok i'm confused. on this http://mobile.jlaudio.com/pdfs/7876.pdf page it says all dimensions are external. but the port dimensions say internal. so do i use internal dimensions on the port or external?
#33
High on diesel fumes
Internal - you need to build the correct cross-sectional port area and the right length, regardless of the external dimensions of the material you use.
Here's what I used when I built my box
http://mobile.jlaudio.com/support_pages.php?page_id=165
And here's my box, can't pass up an opportunity to show off
#37
Depends on what you want. Competitors tune it high, like those mid 50's you were mentioning, because that's what gives them the highest dB rating. I can't remember now if I got 33 hz from the sub MFG or if that was supposed to be good for daily listening.....but I'd say you probably want to be between 30 and 35. I'm sure Snake Eater can help you more than I can.
#38
nice box by the way. well i went to a couple calculators and one took all the info from the sub itself and said to tune to 30.4 i guess. so i played with another calculator useing jl's diameter they gave (had to find more math to convert square inches to diameter lol) and it said for 30.4 htz i needed a port length of 32 inches i think it was. so played around and figured out that jl's daigram for there box is tuned to about 32-33 htz. lol its like being back in math class. so if i do this all right the 2 jlaudio 12w6v2's with say 800-1000 watt rms should pound prety hard.
#40
got this from jl audio just for w612's behind the 3rd row in a tahoe tuned to 34 htz ported. hhaaa that was much easier lol. i email the guy told him what i was wanting to do. he said sound like i had my work cut out for me and to try this one instead lol.
