nnbs bose surround speaker sizes
I'm getting ready to replace my fronts this weekend in an 08 with Bose (using 6 1/2" Boston Pro component set) and I know the stock front mid ranges aren't any known size. They're actually a plastic speaker housing and mounting bracket all in one with a tiny magnet set in the plastic. I purchased a Scosche plastic adapter that you can use to mount the 6 1/2" speaker into and then mount that assembly into the door. You can fit a 6x9 into the door if you wanted (not sure why you would). The stock Bose speakers are 2 ohm by the way, so if you're not amping the new speakers, you're likely to lose a little volume or possibly have problems with the stock amp overheating. The Bostons I'm using are 3 ohm, so hopefully I won't have too many problems (they'll be amped later).
Superman09
09-25-2015 05:55 AM
Alvin@PCMofNC
09-03-2015 06:38 AM
