No Capacitor
Old 01-11-2008 | 11:11 PM
ReSpAwN DeMoN's Avatar
Default No Capacitor
Does not installing a capacitor on your sound system ONLY effect flickering lights?
Or can it shorten the life of the alternator?
I don't got a powerful system its just an MTX-500W Amp
Old 01-12-2008 | 12:23 AM
larsy87's Avatar
apple bottom jeans
A cap is to a sound system like a bandaid is to a gunshot...whats it gonna do? Look effective, but not doing anything.
Caps do help with voltage spikes, but only really minor ones - getting large voltage dips means you should be looking at upgrading your wires, possibly a bigger alt, or a second battery. (maybe)
Old 01-12-2008 | 12:58 AM
Alright cool, so I won't have to worry.
Someone tried telling me that, so I was just making sure/getting worried.
Ya I don't think its dropping voltage TOO terribly. Even on the hardest hitting songs the voltage meter don't even move. I should be fine then..
Old 01-12-2008 | 10:33 AM
truckmann's Avatar
I agree you should be fine.
Old 01-13-2008 | 10:03 AM
Eskimo's Avatar
If you have access to an old needle-style multimeter that's quick to respond, put that at the battery terminals on your amp and crank it, see how much voltage drop you get.
The factory gauges are typically pretty dampened. Try putting your dome lights on and looking at those, they seem to be pretty easy to use as a gauge..
But honestly, if it doesn't bother you, it ain't broke!
Old 02-06-2008 | 11:23 AM
brave4it's Avatar
Default Cap Help
Just be careful with not having one on there. I have a 02 Ext Silverado and I put a Rockford Fosgate 500W Dual Channel and crossed it over and it was fine for about 2 days then it just died. I put a 500W Cap on and it saved my trucks life Because before I put it on I checked the battery and it was totally dead. And put a new one on from the factory when I bought it. They didn't know a stereo killed the battery And a brand new battery couldn't hold up and died as well. So after that I added a 800Cell battery from Pepboys with a 7 year Warranty I think and it was cheaper that a dry cell.
Old 02-06-2008 | 11:28 AM
viciousknid's Avatar
Where's the Beef?
I always suggested a cap because it always helped my spikes. but you can easily do an Alternator Mod.
Old 02-06-2008 | 01:27 PM
krambo's Avatar
I agree, as a former DB Drag world champion (1999) and World record holder SPL 2 sub class, Caps do nothing more than filter out A/C ripple from your charging system and offer some current benifits during short transient events in your signal. A beefier battery, larger gauge power and ground wires and a higher output alternator is your best bet.
I do like appropriately sized caps though as they really do a good job of filtering noise from your power wires which in turn allows your amp to "amplify" a cleaner signal (signal meaning power, not the RCA inputs).
Old 02-06-2008 | 05:30 PM
larsy87's Avatar
apple bottom jeans
What did you compete in? I want to compete next year in the under 1K watts class, or single 12"..depends
Old 02-06-2008 | 07:09 PM
krambo's Avatar
PM Sent,...don't want to thread hijack
Quick Reply: No Capacitor
