power thur fuse?
Old 02-06-2006, 12:45 PM
stone150's Avatar
Default power thur fuse?
when i use a fuse as a power source do i buy a special fuse or just hook into a fuse socket with the fuse. does anyone have pics or a know a good fuse to hook into for little led's?
Old 02-06-2006, 11:18 PM
stone150's Avatar
anyone? how did you hook up your accories?
Old 02-07-2006, 08:16 AM
02BlueStepside's Avatar
To pull power off of a fuse, I used a fuse tap.
Old 02-07-2006, 07:02 PM
stone150's Avatar
what's a fuse tap?
Old 02-07-2006, 07:44 PM
Its just the little brass piece. It goes in with the fuse and has a blade connector on the end.
Old 02-08-2006, 09:34 AM
stone150's Avatar
ok that is what i was looking for, got simething similar but cost too much!, is the dashboard a good enough ground for the 4 led's?
Old 02-08-2006, 09:39 AM
The dash is plastic but there are some metal infrastructures, which are great for grounding things too. Also don't forget to use resistors when installing LED or you will blow them.
Old 02-08-2006, 03:40 PM
Like said above, use the metal under the dash to ground to and you should be fine.
Old 02-08-2006, 06:46 PM
stone150's Avatar
ok the led's i orderedc already had the resistors with them, i jsut don't want to rill any holes in the dash
Old 02-10-2006, 10:55 PM
stone150's Avatar
i'm going to hook into a fuse should i use the ilimination fuse or an ignition fuse?
Quick Reply: power thur fuse?
