power wire for amp...
where did yall drill a hole in the firewall?
im trying to install a system in my girls 1999 silverado, but i wanted to know a good spot so i do drill thru some wires, LOL
thanks
thanks
Grab a flash light and take a look under your dash. All you need is a clear spot on the firewall behind the dash. (find something coming through the fire wall that you can use to reference the spot you picked when looking at the firewall from the engine bay make sure there is nothing behind the spot you picked and you'll be good!!) I recommend drilling a hole on the drivers side, you can rout your wire under the fuse panel and even put your fuse in there if you want. Doing that made my install a lot cleaner!!
PT's Slowest Truck
What guage wire are you using? For my Basslink I was able to use the factory grommet on the driver's side, under the brake booster, where the factory harness passes through. I didn't use really big power wire though (can't remember what size actually, but definitely not like 0 guage or anything like that). If you're using some monster wire, you could drill a hole right around where that factory harness is, there's some blank space there...probably right beneath or next to the factory harness.
Here's mine...
Here's mine...
PT's Slowest Truck
Originally Posted by 2k4tahoe
i was looking at that last night, and wondered if i could sneak the wire in that. i think its like 8-10 guage, just running 1 semi small amp.
