racettonix hot wire kit
I just installed a racetronix hot wire kit for my walbro 255. Truck ran no the 5 min before I installed the wire kit. After installing the wire kit, I tried to start the truck. Fuel pump doesn't prime, and truck doesn't even try to turn over. Seems like a ground or fuse is messed up. I checked fuses and grounds everything seems to be alright . I need help figuring out what else I should check or try
11 Second Hall Moniter
Where did you ground the harness? Maybe you're right, and the ground isn't good enough.
On a side note, one Racetronix HW kit I installed had the pump harness wired in reverse polarity. Zero fuel pressure, but I could hear the pump run. Pulled the fuel pump module back out, re-pinned the fuel pump connector correctly(swapped the wires in the connector at the pump), problem solved.
I think the hot wire kit is backwards or something. My truck doesn't like it plugged in at all. I had the fuse out of the power wire for the hot wire kit so it wouldn't have power, the rest of the harness was plugged in ground included, and as soon as the key hits on, POP. Fuse pops. So I put it back to stock so I can get it on the road. And now I need to figure out how to fix this wiring kit. Is like to have it to insure the pump has enough volts to it to keep the walbro happy. My buddy has a hot wire kit for his T/A and he said I can try and see if that will work in my truck.
