remote turn on wire
Old 07-18-2011, 04:06 AM
Parke10's Avatar
for the factory deck (as in behind it) there is no ignition wire, its run on the LAN but you can grab it under the column Pink wire grab it at the ignition switch or BCM, lt. green plug, pin 14
Old 07-19-2011, 02:38 PM
2000silvrx81's Avatar
I just ran a wire from the fuse box under the hood on the drivers side. The pink and green wires under the colum didn't work
Old 07-19-2011, 05:59 PM
montyss's Avatar
On the 2007 and up you can get what you want from the MBEC box under the dash by the e brake , its a black box right by where your left leg would be....
you can by a connector GM part # 20791502 that fits into into the X14 position in the cavity of the box , this connector can supply 15 amp power 30 amp power or RAP but this is only 300 milliamps so you have to have a relay with this one , this is what I used for a amp trigger wire using the radio wire caused my amp to pop and this cured it.
this is the location that aftermarket accessories can be added to the GMT 900 trucks
there is someone on GM-trucks .com that makes this harness up complete if you are interested in one ....
google this
Electrical Manual – 2009 Light Duty Full Size C/K Trucks this is on page 669-670
Old 07-19-2011, 06:02 PM
montyss's Avatar
here is some more info ...
Big Thanks To Cgalford And His Upfitters Port Connector. - GM-Trucks.com
Corvette454l88
09-01-2016 01:24 AM
shawn96gmc
05-17-2016 04:15 PM
Y2KLimited
12-05-2015 09:57 AM
03regcab sierra
20
08-03-2015 12:11 AM
Quick Reply: remote turn on wire
