Running wires from door to cab 06 silverado
I usually run my wires through the black rubber loom and boot. Some wire looms are too tight to fit extra wires. On thoughs I would still run the wires through the boot but pass on the outside of the wire loom. I would then run some sort of QUALITY electrical tape around the loom to hold the wire against the loom. Wraping in a helical motion. If you use crap electrical tape it won't last long and end up being a sticky mess in a matter of months. Good stuff (3M!!!) will last a LONG time and will have a clean look to it if done right. The reason I run mine through the grommet dispite if I can get it through the loom or not is to insure I dont' make any more holes that water can get through. It also holds the wires nicely out of the way so the can't get pinched. ![Nod](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_nod.gif)
EDIT: I usually have to pull the grommet (both sides) and run my wires through it then re-install the grommets to help with feeding the wires.
Mossyoakglock
07-17-2015 08:30 AM
Nimoryan
07-05-2015 03:50 PM
