single cab sub boxes
Old 12-17-2008 | 02:16 PM
02gmcbandit's Avatar
Default single cab sub boxes
wonder what kinda boxes you guys with singlecabs use? im wantin 12's in my 02 but they usually require around 1-1.25 cu ft and that means a pretty decent size box, but i still want to be able to lift my center console without having to shove it and rub the box. any help , pics, advice on box deminions?
Old 12-17-2008 | 02:35 PM
gtosilverado's Avatar
i used to have a downfire box for an ext cab, but i used it in my regular cab. it fits the kicker cvr's nicely.....my next setup will be a probox. My cousin has one, its really nice and sounds better than my old setup. im going with 10's instead of 12's..... http://www.proboxrocks.com/products/...10/index.shtml
you can put 10s or 12s on this probox... from my experience around sound systems, 10''s sound way better than 12''s..... my ideal setup would be 3 10''s, but that wont be til i get a center console like the ext cabs. for now, 2 10''s JL w3v2s are on the christmas list.
Old 12-17-2008 | 02:42 PM
D_reks{5.3}'s Avatar
I had a Treo ssi 10 in a sealed box in my truck but it was .8 cu. still had close if not all my leg room. It was about 8" deep at the widest part. I do not have any pics. But not i am doing a new set up since the last was stolen, I am putting a custom built box n place of the center console with a JL 10W7 ported. Here is a link to a box i thought about getting before my last custom built box.
http://www.subthump.com/gmre.htm
Old 12-17-2008 | 04:41 PM
OneQwikSS's Avatar
formerly 2004RST (changed 11/19/2012)
your best bet in our regular cab trucks is just to build a custom box you can check www.supercrewsound.com but i don't think that they have anything for regular cab trucks...or if anything maybe try e-bay? but if you're looking for something with a little bit of deep bass...talk around your area...i'm sure there's some people that can build a box to fit back there that still hits those lows (depending on what sub you want to go with)
Old 12-30-2008 | 05:54 PM
wesley_burks's Avatar
i have a single 10" box with a diamond audio 10 for sale. it fits perfect behind the seat.
Old 12-30-2008 | 05:59 PM
StrokerAce03's Avatar
Building your own is the best way IMO. It'd be easy to fit 1 12 behind the seats without sacrificing legroom but 2 would require more work unless you went with some shallow mount subs.
Old 12-30-2008 | 07:14 PM
05blacksilverado's Avatar
Registered User
i have 2 10" w3v2 in my singlecab,it sounds decent,can i upgrade to 12 w3v3 s ????what box what you guys recommend????
Old 12-30-2008 | 10:01 PM
bgray's Avatar
TOTM: June 2007
Heres your solution. Everyone knows how hard JL W7's hit...they hit hard. IF you have ever heard a W7 8" you know the output and incredible quality they perform too....You only need 1,
Here what me and my dutch wood-wizard did...
Its deifnetly way to small of a box for a w7, but amped properly it sounds great
Old 12-31-2008 | 12:17 PM
blueflamed03's Avatar
Kicker TCVT12 box, slim and pre-loaded ready to hook amp up too...
Old 01-03-2009 | 01:22 PM
Rage_89's Avatar
I have a single ported 12" box that goes from the passenger side wall to about the middle of the jump seat/center console. I had a Treo TSX in it and it'll rock your world guaranteed. I need to get rid of it too, PM if you're interested.
