sizing an amp to a sub
first off i know nothing about car audio, so bear with me.
how much amp should i have for a sub? equal to max rms power? equal to max power handling? more?
say im looking at a sub with a rms power range of 500-1000watts, with a max power handling of 3000 watts. how much amp do i need?
Ive found out that most of the cheaper amps dont actually put as much wattage out as they say. Get something with a good name behind it, if its 500-1000 rms then get something around a 800 watt amp. You could even get a 3k watt if you wanted, you can always adjust the amp to your likings.
Some companys subs tell you what their ideal power range is. My JL W7 10" is 250-750 rms and 1500 peak, JL says the ideal wattage is 500 watts..
peak or max power/watts means jack squat. to get that they test it at impossible real world conditions for just a few seconds. just get a "Good" amp, good being the key word there obviously. and match its power output with your rms at the correct resistance your using and you should have plenty of thump. and dont skimp out on good ground and power wires for the amp..
Say the specs on your speaker is 750 RMS and its a dual 4 ohm voice coil. You can bridge that one speaker down to 2 ohms, so you want an amp that is going to put out around 600 to 800 watts at 2 ohms. If you had 2 of said speakers, you would want an amp that put out 1200 to 1600 watts at 1 ohm. There are alot of online calculators to help with this. Kicker, and JL audio I believe still have them, its been a while since i have used them. Read up a little bit and get a better understanding of things. Also you can buy all of the top of the line equipment you want, if you don't put it in the RIGHT spec box, it will sound like $20 crap!!!!
Closer_2001
09-24-2015 09:15 PM
