Stand Alone Harness Gauges Advice
Im wrapping up a 5.3 swap on my truck, I’m running a stand alone harness but as it entails I have no gauges what would you guys recommend? I was thinking some Glowshift or Autometer gauges but also had a digital cluster in mind. Thanks for your time.
I mainly want gauges for the speedometer and oil pressure the standard readings.
the answer will be largely dependent on what you're using to control the engine, and whether you have provisions for a VSS or not. So we need some more info on your swap
Chassis?
Computer?
Harness provisions for gauge output?
Budget?
Seems like a lot of the digital clusters are GPS speedo and canbus the rest of the info
Chassis?
Computer?
Budget?
wretched73 (09-12-2024)
jamesx17x
04-04-2024 01:45 PM
