Sub wiring question
Old 12-22-2011 | 01:28 AM
LaResvalosa's Avatar
Default Sub wiring question
Okay guys so here's what I have. 2 12" kicker c12 300w single voice coil 8ohm, 2 10" audiobahn AW1051SE 300w dual voice coils 4ohm, and a 1200w mono planet audio amp. Now my question, is it possible to wire those 4 subs to just that amp? I currently just have to 2 c12s hooked up to the amp but I have that extra set of audiobahns that I wanted to hook up too to pound louder. Any ideas?
Old 12-22-2011 | 08:19 AM
Black08Chevy's Avatar
You can hook all 4 subs to one amp but you really want 2 amps. To make all 4 work off that one amp 2 subs would be sharing one channel. Id suggest just gettin another amp to handle the audiobahns
Old 12-22-2011 | 10:00 AM
blueflamed03's Avatar
no, your aksing for huge trouble...the AB dual 4's will wire to a 1 ohm load, leave the Comps off.
Old 12-22-2011 | 11:14 AM
It's a mono D so I'm just working with a single channel. Could I parallel 3 of them into the amp. The 2 c12 making 4ohms and then 1 AB adding another 4ohms bringing it down to 2ohms total? Also if I had to just stick to one set which one do you think would hit harder the 2 c12's or the 2 AB's? In a single sub sealed truck style box. (the little angled ones).
Thanks!
Old 12-22-2011 | 01:59 PM
Silverick's Avatar
I am not a stereo guru but, I had the stereo in my truck worked on last weekend and
I have 5 - 10" JL Audio subs wired to 1 - Lanzar 50C Opti amp. It sounds great!
Old 12-22-2011 | 02:54 PM
blade7022's Avatar
Thanks!
Theory would say to stick with the 12's. The only whay to increas speaker ouput is to increase cone area or power. But at single 8ohm coils, the best you could do is 4ohms to the amp. If the amp is 1ohm stable, and has a better RMS ouput at 1ohm, the AB's could be the better choice. And as blueflamed03 said, your asking for trouble trying to wire multiple coild configurations together.
Old 12-22-2011 | 03:33 PM
I guess I'll just stick to my c12's for now then. Is there a way to make those louder tho? Could I port my single sub sealed box with a small hole or something to let all that trapped air out?
Old 12-22-2011 | 03:56 PM
alright guys heres what im pretty much running. 2 of these
KICKER 12" LOADED 2010 C12 SUB TRUCK SUBWOOFER BOX NEW | eBay
i was thinking i could port my boxes with these right here
3" Port Tube Subwoofer Sub Woofer Speaker Box Pro Audio | eBay
2 of those 3" ports in each box, one on each end. what do you guys think?
Old 12-22-2011 | 07:22 PM
blade7022's Avatar
Ported boxes are a whole other animal. They require more cubic feet of air space in an enclosure to get to a proper tuning frequency. Porting a small sealed box would yield a very unfavorable tuning frequency, it would be way to high and make you subs sound like mid-basses.
713truck
08-18-2015 10:32 PM
Jblake
08-17-2015 01:59 PM
USMCvet0311
08-01-2015 08:45 AM
