Tachometer Reading Half?
I Have An 03 Gmc Truck With The 5.3 And I Just Installed The A 5" Tach On It. I Attached The Green "coil Wire" To The White Wire On The Back Of The Guage Cluster And I Am Only Getting Half Of The True Rpm. I Need To Know Has Any One Had This Problem And How Do I Fix It?
Originally Posted by JOBLOW06
I Used The Autometer "autogage" Series (the Cheapest) And Cut Both The Orange And Brown Wires. This Set It Straight And Thanks Again For The Help.
Sorry, No Camera Or Scanner Here. I Mounted It On Tha A-pillar With These Little Foam Blocks On The Backside. I Got The Blocks From Hobby Lobby. My Concern Was That The Plastic Piece Wouldnt Hold Up. The Blocks Are About 1/4-3/8" Thick And Have An Adhesive On The Back. They Hold Well And There Is No Flimsyness Whatsoever On The Pillar Cover. Worked Out Really Well. I Ahve Also Seen Them Mounted On The Trans Hump Pointing Up At The Driver, Just For Your Info.
calsdad
06-14-2023 11:07 PM
