Tahoe doesn't respond to key fobs anymore
Old 12-27-2013 | 01:26 PM
TX Tahoe Z71's Avatar
Default Tahoe doesn't respond to key fobs anymore
Yesterday, my key fob remote stopped working, both lock and unlock. Thinking the remote had gone bad, I grabbed my other remote and that one didnt work either. I recently replaced both batteries.
What typically goes bad on the truck when remotes stop working? How can I test the different parts?
Thanks guys
Old 12-28-2013 | 02:23 AM
Try holding lock and unlock together 7 seconds but sometimes I've had it take 20 to 30 seconds. If they are transmitting this will resynchronize the transmitter to the PDM (passenger door module) if the rolling code got out of whack. The truck will respond by locking and unlocking the doors when resynch is complete.
Start with new batteries in both remotes
Old 12-28-2013 | 06:52 PM
I'll try that, then new batteries. Thanks for the suggestions
Old 12-28-2013 | 10:34 PM
Holding the lock and unlock at the same time worked! Took two tries but the second time worked and re synchronized the remote. Huge thanks and gig 'em!
Old 12-29-2013 | 12:19 AM
NP that's why we're all here I hope.
Old 12-30-2013 | 06:15 PM
Whelp, it worked fine for a bit, then stopped working, then started working again, but now seems has stopped working for good. Changed the batteries with new and tried the resync a number of times but no luck. The truck doesnt respond to the back up remote either. What else could it be?
Old 12-30-2013 | 09:18 PM
The keyless entry/tire pressure monitoring is built into the passenger door module. It's the switch assembly. IF you installed new batteries in the remotes already and it's still doing it chances are the door module is failing. You could always pull the door panel and disconnect and reconnect the wiring harness connectors on the off chance it is making a poor connection.
If you haven't put new batteries in the remotes it could be aggarvating the rolling code algorithim and confusing the keyless entry module making it not recognize the remotes when you use them.
The new PDM needs to be programmed for your truck.
Old 12-30-2013 | 11:53 PM
I did pull the passenger door panel off and disconnected the switches a few months ago to fix a speaker problem, so could be a loose connection, I'll try that. So it is part of the lock/unlock and window assembly in the passenger door?
Again, thanks for the help
Old 12-31-2013 | 01:27 AM
Kinda. The door lock/ window switch assembly is the passenger door module. It contains the keyless entry and tire pressure monitoring system internally.
Old 12-31-2013 | 05:02 AM
TIM Z's Avatar
11 sec. Truck Mod
Good info here thanks guys . Let us know what ya find TX Tahoe
