Truck wont start
Old 10-29-2008, 12:31 AM
Formerly Low_LQ4 - 6/6/10
Low_LSX's Avatar
Default Truck wont start
I put my key in the truck and it wont start for some reason. I hear a ticking sound under the dash check the relays and they are ok but the sound is from the relay. So I swapped it with a new one and same thing is happening. Anyone know what this could be? Thanks for the help.
Old 10-29-2008, 12:38 AM
nonnieselman's Avatar
sounds like a dead battery??
Old 10-29-2008, 10:47 AM
High on diesel fumes
thunder550's Avatar
+1 try jumping it.
Old 10-29-2008, 11:20 AM
eddie_da_chevy_guy's Avatar
+2 jump it
Old 10-29-2008, 11:34 AM
00Silv4.8's Avatar
if ur overhead light its dim and then going out or flickering when u turn the key its the battery. Some times jumping wont work because the battery is so old, or just too weak. I hate to say it but I think u need a battery man.. maybe just switch the one from the "beater" for a trial run?
Old 10-29-2008, 02:50 PM
Low_LSX's Avatar
I'll give that a try.
Old 10-29-2008, 02:52 PM
Wearin' da big hat
00ChevyScott's Avatar
Don't hook it to the battery when jumping it in case it has a bad cell.
Hook the positive up to the + on the battery and the ground on your alternator/block.
Old 10-29-2008, 05:00 PM
StrokerAce03's Avatar
Don't do that either. Ground it to the alternator and put the positive on the bolt inside the red jump box.
Old 10-30-2008, 11:43 PM
Low_LSX's Avatar
Tried that and it didn't help ran a scan with HPT and got these codes:
B1001-Vehicle Option Configuration Error
U1000-Class 2 Data Link Malfunction
U1016-Loss of PCM Communications
U1096-Lost Communications with Driver Information & Displays Control System
Old 10-31-2008, 12:02 AM
Wearin' da big hat
putting the + on the battery vs the red box doesn't change a thing. The battery bolt is connected to the wire that runs directly into the red box...
Quick Reply: Truck wont start
