Weird Electrical Problem, Would Like Some Opinions
Old 07-23-2008, 05:35 PM
High on diesel fumes
thunder550's Avatar
If I'm reading it right, you have the G401 ground setup. Here's that one as well.
Old 07-23-2008, 05:40 PM
thunder550's Avatar
Instrument panel
Old 07-23-2008, 06:03 PM
KySilverado's Avatar
I've read about LED Third Brake lights causing problems you are describing. Something about them going to ground. Think I read about one or two posts here. Unhook it and see?
Old 07-24-2008, 06:12 AM
Notorious BIG
Holty's Avatar
Thanks for the replies and the schematics, i'll post back with my findings.
Old 07-24-2008, 11:16 AM
PT's Slowest Truck
budhayes3's Avatar
Originally Posted by Holty
yes, the back up camera is activated when the gear selector is in Reverse.
If it's wired directly into the reverse light harness in the back of the truck, I'd check there first
Old 07-24-2008, 12:48 PM
Moderately Differentiated
dewmanshu's Avatar
LOL @ Holty and schematics
Old 07-24-2008, 02:05 PM
THE-HOE's Avatar
I had the same problem with my turnsignals, my horn quit working too. I started searching grounds and found a lose ground on the driver side radiator support. Its up past the rubber mount facing the front of the vehicle. i cleaned it up and tightned it down and the trunsignals worked fine. so check that one out
Idryfly5
09-02-2022 08:55 PM
Go5.3tt06
25
09-04-2016 10:25 AM
mikeyjm1
17
10-29-2015 11:04 PM
kalikid06
20
10-13-2015 07:37 AM
Alvin@PCMofNC
09-03-2015 06:38 AM
Quick Reply: Weird Electrical Problem, Would Like Some Opinions
