What would cause my amp to cut out??
#21
im going to wire it like this:
1. amp + to voice coil 1 +
2. voice coil 1 - to voice coil 2 +
3. voice coil 2 - to amp -
i hope this ^^ makes sense, and doesn't catch my truck on fire or anything, lol.
#22
Originally Posted by CHEVRACER83
But Les His Amp Is Only Stable To 4 Ohm
what you need to do is hook up the + channel to + coil and same for - on the same coil.... then wire your - + together on the other coil
sorry i have a problem with not reading everything in a post... im a "skimmer"
#25
Originally Posted by 2002C5COUPE
ok thanks a lot guys!
im surprised i havent messed that amp up by running around so long with it like this!
jfwy!
that fosgate diagram could be really handy!
#26
Originally Posted by '89ChevyMadneSS
hence the two warrantied amps
jfwy!
jfwy!
#28
ok i rewired my sub to run in series, then i put it all back in and tried it out and............nothing! lol
it sucked
i took it back out and found a voice coil wire had broke off of the terminal, i rigged it back up, and it works now
it's 1,000,000x better than before when it was running at 2 ohms! lol
thanks again for the help!
it sucked
