Why does the stereo in my truck suck?
I have a base model 04 RCSB truck with the single disc cd player and AM/FM radio. The stereo system in my truck sounds like a damn tin can. I know how to operate all the settings on the stereo and go through all the sound modes and it still sounds cheap. My 03 GMC Sonoma SLS reg cab truck really bumps hard (for a factory stereo) but the one in my silverado sucks. Does this have something to do with the fact that I have a base model truck? I tried shining a flashlight in my door panel speaker grilles and I can see there's a tweeter but it looks as though I have plastic filler plates in place of where a 6 1/2 inch speaker should go. Or do they put fabric over the speaker so its not visible? Does anyone else have a base model truck? Can they verify this for me? Do I have a cheaper deck in my truck since it's a base model? Are the speakers cheap or junk? I can't believe the sound difference between my 2 trucks. Also, since we're talking about this. How hard would it be to install a factory BOSE stereo? Is the deck any different? Is there an amp that I need to install? Can I just plug the speakers in my deck I have now and expect it to work? Thanks!
Joe
Joe
there is fabric covering ur speaker and sound like crap is typical of stock no offense, I had the bose system in my truck i couldnt stand how bad it was i riped it out in the first month of owning my truck,
you can read through this thread theres some good info in there on what to do
https://ls1tech.com/forums/showthrea...aker+questions
I have the base model...radio only and it sounds better than I thought it would. I had a Sonoma that I put a Pioneer deck (50w x 4 ) and upgraded the door ones with Sony Xplods and the dash ones with Jensens,I think. Sounded noticeably better but the stock junk didn't sound too bad. Maybe some of the stock stuff is damaged.
I don't run mega-power stuff so you might be looking for much different results than me.
No, my stuff is mainly classic country and musical scores from my favorite movies. I like a little bit of a rumble but not a tin can sound like an old 1930's radio. So hard would it be to do a factory bose install on my base model truck? Anyone know what parts I'd need?
to even fuss with the bose wouldnt be worth it, I would have gave u my stuff but i tossed it, but you have to go through and mount the bose amp and run the wires from that to the speakers and have a big hassel for mediorcar speakers, if you wanna do it simpl just get some decent after market 6.5s ( hopefully components ) and be done with it.
Stock stereos suck! They just do
You're only real hope of beter sound quality is a new head unit and speakers. Even a good head unit (with x-overs built in) will help the stock speakers sound better.
For budget builds we usually swap out the font speakers, add a sub and a small amp to power it. If you mainly listen to classic country (zero bass) then the sub prolly wont be of much use. Get a good deck and the best front speakers you can afford.
Just keep in mind you have an 04' GM which uses the class 2 databus system so install of the deck will be pricey because of the adapters you'll need.
