Will aftermarket deck ruin sound quality?
Formerly 08_gmc_slt-08/20/2010
So when I had my 02 Camaro, it had the Monsoon system in it. I purchased an Alpine deck and my sound quality reduced dramatically (less bass, sounded muffled) so much so that I put the factory deck back in.
So now I have an 05 Sierra with the Bose system in it. I am wanting the Alpine IVA-W200 but have reservations if the same thing is going to happen. Does anyone have any experience with this in their trucks?
did you previously account for the remote located amp in the monsoon system? the Bose system is set up the same way, they have remote located amps that the head unit feeds into, if you bypass the stock amp there is no reason why the sound quality would degrade when using a quality aftermarket deck.
Also whats with all of the little dolphin animations, or the riceburners racing down a hill, or waves crashing??
you want me to buy a head unit... gimme a animation of a chick screwing a midget...
![The Jester](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_jest.gif)
you want me to buy a head unit... gimme a animation of a chick screwing a midget...![The Jester](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_jest.gif)
my pioneer i can make custom animations.... i have one of my truck doin a durn out
Thanks for the replies! Now how hard to install? Since this is a DVD player, how can I bypass the whole "emergency brake on to watch" thing? Would like the wife to watch while we are driving.
Originally Posted by exhappen
I be surprized if it actually sounded worse. I just can't stand the way aftermarket decks look. 50 dinky *** buttons all over the thing.
With regard to Bose integration, check out soundgate.com, pie.net, and pac-audio.com for the various interfaces. I forget all that's available, but you'll need something to adapt the new deck to use the Bose speakers. If such a device is not available, you'll need to replace the amp & all the speakers as well.
you will have to find a bypass switch because its an alpine (they require you to press the brake then the ebrake then let go of the brake) also the passengers view isent that great due to the angle on the dash.
