TECHNICAL WRITE-UPS A place for great instructional threads by members and moderators.
DIY bed liner
Old 05-25-2016 | 11:43 PM
  #31
1FastBrick's Avatar
Custm2500's Rude Friend
Originally Posted by Wolftrk99
Does it look like and have same texture as bedliner??
The 3M product has a slight rough/orange peel like texture to it.
Last edited by 1FastBrick; 05-25-2016 at 11:45 PM. Reason: It is not clear, its grey
Old 05-25-2016 | 11:45 PM
  #32
1FastBrick's Avatar
3M Rocker Panel Coating, 23 ounce Net Wt / 600g, Grey, 08889
I am mistaken. It's grey and you paint over it.
It's only been 10-15 years since I last used it or was around it.
Old 05-25-2016 | 11:48 PM
  #33
Wolftrk99's Avatar
Interesting, when i finally get around to fixing my paint i may have to get some of that....
Old 05-26-2016 | 10:43 AM
  #34
Mark Johnson's Avatar
Wow- 15 years and still holding up.............
Old 05-26-2016 | 04:54 PM
  #35
1FastBrick's Avatar
Thats the last time I worked in or around an actual body shop.
Old 05-26-2016 | 05:37 PM
  #36
Wolftrk99's Avatar
Old 05-27-2016 | 01:50 PM
  #37
Apparently most of the coatings are pretty good, it's all in the prep............
Old 05-27-2016 | 01:58 PM
  #38
Wolftrk99's Avatar
Prep will make or break any coatings longevity... Uv resistance is the other aspect, wron uv resostance will cause more than just fading in some cases....
Old 05-30-2016 | 01:06 PM
  #39
Cool- have a good idea what I'm looking at. Say, B4 I paint in the liner I wanna put it a ladder rack that I had on one of my previous trucks and that had some kind of nut insert thru the sheet metal, here's some pics of what I've dug up; one recommendation over the other? I like the one that collapses, but am concerned than it will turn when trying to tighten a bolt in there. TIA
Old 05-30-2016 | 01:26 PM
  #40
Wolftrk99's Avatar
The crush ones tend to turn, the solid splined ones will too if overtightened, creating a bigger issue than just a turning nut!!!
Quick Reply: DIY bed liner
