Installing 06 Chevy E-fans on a 01 Chevy
PT's Slowest Truck
Nice write up man...just a note, for most guys with 1500 trucks, you will be replacing the radiator before dropping the efans in, and will have to trim the rubber flaps along each side of the radiator, or about 3" of the radiator core will be covered by these flaps on each side. Also, as I found out when I originally did my 05 efan swap, if you have a K&N FIPK for a 99-04 1500, it's shield will need to be modified to clear the new 34" radiator as the shield and rad occupy the same real estate
PT's Slowest Truck
Yessiree, the C3's are different, like the Silvy SS's and VHO's, all of which already come with the 34" rad, so the K&N FIPK for those models will not need modification. I suppose that if somebody was installing the 05+ fans in their 99-04 4.8-5.3 1500, and wanted an K&N that didn't need modification, they could always order one for either an 05+, or a C3, SS, etc. Part of the reason that I now have a Volant, and used to have a K&N, is that the Volant was a direct bolt-in and cleared the 34" rad. My modified K&N actually came out nice, but at the time I had the dough and wanted something a little sharper looking
