1978 Z28 Street/Strip
1978 Z28 Motor is a 454 .040 over with 049 Open Chamber Heads, Competition Cams extreme energy 555 lift cam, Edelbrock Performer RPM Intake, Harland Sharp , RollerRockers, ATI Super Damper, Mini Starter & SFI approved FlexPlate. Runs Great., Worked proform bodied HOLLEY 875 cfm Double Pumper, K&N filter with Hi Flow top, Steel Braided fuel line, Nitrous Oxide Cheater System with 125 HP Jets, NOS purge, NOS BigShot Noids, Complete Stand alone Fuel System with 1 Gal fuel cell and Holley Blue pump with regulator and braided line, New GM alternator, New belts, NEW power steering pump and hoses, Hedman headers with 3inch exhaust and 40 series flowmasters, Built driveshaft, Welded in competition engineering subframe connectors, Built 400 turbo with 3400 stall and B&M Stealth Pro Grip Shifter. Built 12 bolt 373gears 33 spline Moser axles and spool with long studs, Aluminum Ultra Star wheels 8's in the rear with M/T 26 X 10.5 ET Street tires, 15 X 4 Skinnies in front with new tires, New door panels, carpet , headliner all black, Seats are stock camaro have been dyied black on front seats. Completely rewired car..all NEW HOTRODWIRES wiring kit 16 circuit. has front and rear swaybars still on car, 90 10 front shocks on front. CE traction bars on rear. New battery and NOS bottle with heater & blanket mounted in the trunk. Body was reworked and car put in Black Urethane Primer, Custom stock lights professionally smoked black on rear, sidemarkers and turn signals, Harwood bolt-on fiberglass 4" cowl hood. All NEW Auto gauge Gauges speedometer, tach, nos press, oil, temp, volts etc...etc....$8500/Trade for Truck.
whitelazer
09-22-2015 09:38 PM
