Texas We've Seceded from the Union
99-06 Silverado/Sierra hidden antenna mod
Old 04-23-2012 | 12:55 AM
KITT's Avatar
Default 99-06 Silverado/Sierra hidden antenna mod
Buddy showed me a cool way to hide the antenna on my tahoe and crew cab. Not sure if someone already made a thread on this but here it is:
Time to complete was about 10mins
First I popped off the 3 clips holding that black plastic triangle with the little flap on it.
after removing you will see the 3 bolts (9mm if I recall) holding the antenna up and as you can see I already removed it.Name:  photo3-2-1.jpg
You can play with the wire until you find a good spot to lay it so that the hood bracket does touch it. I also wrapped electric tape around that piece to keep it from making a metal to metal vibration while driving.
then you can tuck the rest of the antenna under the rubber flap that goes along the edge of the inside of the hood.Name:  photo2-1-1.jpg
then i just zip tied the end of it to a hole that i found there by the rubber piece.
this is what it looks like finished and you can fill the hole with whatever you want or just leave it like that. Ive haven't noticed a difference in sound quality or static with my radio. Hope this helps.
Old 04-23-2012 | 01:11 AM
JFOLM's Avatar
There is a cover that you can get off an Escalade that doesn't have the hole for the antenna.
Old 04-23-2012 | 01:13 AM
Mangled03gmc's Avatar
Baltimore Whore
Old 04-23-2012 | 01:27 AM
KITT's Avatar
that would work even better lol
Old 04-23-2012 | 12:35 PM
tylertxss's Avatar
I did this about about 2 years ago, if u want to clean it up you can make a bracket for it instead of using zipties.
Old 04-23-2012 | 02:24 PM
colekill's Avatar
KickinAssAndTakinNames
yeah i did that a few years ago too and i thought i was pretty slick. but i put it back after week due to shitty AM reception. I listen to my ipod and AM, never FM.
Old 04-23-2012 | 02:32 PM
LowSilver's Avatar
I had mine done really easy. Someone bent it, I snapped it off and it still seems to work fine! haha. Cool to see it done the proper way though.
-Kenny
Old 04-23-2012 | 03:35 PM
KITT's Avatar
-Kenny
haha yeah that seems easier than my way.
Old 04-24-2012 | 06:31 PM
wheeliE-maxx's Avatar
I have the esky cover on mine. Did you do a ground wire on yours? I didn't and don't get **** for am/fm/hd reception.
Old 04-26-2012 | 01:47 PM
KITT's Avatar
No I didn't ground it and all my stations work great even my iPhone transmitter
madmann26
04-29-2020 10:17 AM
02AWDAWSDenali
10-01-2015 06:08 PM
DrX
09-29-2015 05:31 AM
bisqikss
09-27-2015 10:40 PM
GM1697
09-09-2015 11:31 PM
