CAD users
CAD users
To all CAD users I have a few questions.
Which program do you prefer, AutoCAd or Solidworks
Are you self taught or did you take classes
How long did it take you to get proficient
What do you think or do you recommend any online courses
Ive been wanting to learn this for awhile so now is the time. Any info you have would be appreciated. I wish I had a copy to play around with.(hint)
AutoCAD for me! Self taught but worked in the structural and architectual department of a company so I was surrounded by it. No classes just asked questions and played with it CONSTANTLY! It took me about a year to get really solid on it. I never got too much into the 3d drawings but we would do isometric drawings instead of using the 3d side of AutoCAD.
You can find copies on line that will work. Just need a crack (which can also be found on the net) AutoCad is a LARGE file so pulling it off line is ideal. Unless you want to do the full 3d drawings AutoCAD LT of any year will work perfect for you to learn on. I prefer the somewhat older versions because of their ease of use. AutoCAD 2004LT was the last version I was using. Its a pretty solid program!
I have been using CAD since 1987.
I used Unigraphics from 1987 until 2006. I then changed jobs and have been using Solidworks ever since. I went from 2D (1987-1989) to 3D wireframe (1989-1993) then to Solid modeling (1993-present).
I used to swear by UG, but now I prefer Solidworks. I used Autocrap a few times and trust me, Solidworks is 1,000X better. Simply no comparison.
I suggest learning Solidworks, they have an online tutorial that comes with the license that is pretty decent. If you plan to make a career using CAD, the number of employers using Solidworks far outnumbers Autocad...and the quality of the jobs is typically much better too.
Pro-Engineer "Wildfire" is another top-notch CAD platform.
What type of Engineering are you going to do with it?
Good luck, have fun!
I used Solidworks all through college and during an internship, then at my first job I used pro/e (wildfire 3 I believe) exclusively for 5 yrs. Now Im back to Solidworks. I recommend it 100x over Autocad. Its much easier to learn in my opinion, a lot of the operations and icons are more intuitive, especially when compared to pro/e. Its my personal preference for 3D modeling software.
solidworks is good. my license ran out which sucks so i use mastercam now which is not bad but no where near as powerful as a dedicated modeling software. like was said they have step by step 'projects' so you learn how to use it from that. if your a student you can get it for a little over a hundred bucks but you will need a relatively new and powerful computer to run it
I use solidedge at work, but have used solidworks and autocad in the past. Soldiworks is my favorite to work with. It is fairly user friendly and easy to use. The best way to get good at any of them is to just practice. Draw items for your truck, bike, anything. Once you learn basic modelling you can move to complex curves and contours and do some awesome designs. The assembly functions in solidedge/ soldiworks are awesome too. If I was going to buy one package it would be solidworks
