TOOLS & FABRICATION Hand | Power | Hydraulic | Pneumatic | Welding
Can I Swiss cheese my hitch receiver?
Old 11-01-2012 | 10:51 PM
Chevy_freak's Avatar
I'd just shim it myself. I've never seen anything so over and under engineered at the same time as two pieces of tubing with 16 bolts.
Old 11-01-2012 | 11:09 PM
Koots's Avatar
It's a weird way to fix that problem, but I don't see a huge problem with it...unless you start pulling some serious weight.
I wouldn't be surprised to see a good bump in the road deforming or busting a few bolts though...welding on some nuts like mentioned before would probably fix that issue for a while.
Old 11-02-2012 | 01:09 AM
Spoolin's Avatar
GFYS and STFU
Decided that when I get around to it that I'm gonna weld a second receiver hitch onto my tow bar and weld a second receiver tube the that hitch carrier. So instead of the whole thing hanging off one attachment point it will have two.
Used it last weekend and it worked ok. Wobbled a little bit but the main problems were that it is not level, the driver's side of the carrier is about 6-8 lower than the passenger side, so when backing up or driving up a steep driveway the carrier will scrape.
Another problem is the carrier is made in China...so it is under engineered and if I tie the straps down too much the whole thing "bannana's".
Old 11-02-2012 | 01:19 AM
Mangled03gmc's Avatar
Baltimore Whore
Drill a hole in it, put a shoulder bolt through it with a hole that is just enough to get it through. Should take alot of slop out of it as the pin that holds them is already a bit bigger then the tin..
Old 11-02-2012 | 01:27 AM
Spoolin's Avatar
GFYS and STFU
What's a shoulder bolt John? I'm up for any temporary solution right now.
Old 11-02-2012 | 01:37 AM
Baltimore Whore
You can use one with a hex head. If you drill a hole towards either end with a hole that is just bigger then the bolt, it should take A TON of slop out of it.
Attached Thumbnails Can I Swiss cheese my hitch receiver?-stainless-steel-shoulder-bolt-14398-2264615.jpg   Can I Swiss cheese my hitch receiver?-bolt-dimension-arrows-424x382.jpg
Old 11-02-2012 | 02:10 AM
Spoolin's Avatar
GFYS and STFU
Cool never seen those. Might have to check it out.
Old 11-02-2012 | 02:30 AM
Baltimore Whore
Really? never seen them before? All the time you have spent on a ship. Thats kinda nucking futs.
RustyD
05-23-2016 08:04 PM
Alco
10-04-2015 07:58 AM
TrickTurbo
09-23-2015 09:41 PM
Quick Reply: Can I Swiss cheese my hitch receiver?
