Welded my v-band and surface not true
Forgot to clamp my v-band together before welding now surface not true. Very minimal gap . I'm worried because my o2 sensor is very close and don't want air to affect it.What is the best way to true both up? I tried fine file cross hatching and getting close but need another method.Thanks
Once I get it closer to acceptable I will give it a try.
Not the problem its the actual v-band surface thats a little warped. thanks
Need it perfect so both sides match think chop saw might be to risky. thanks
wasent the pipe cut that was bad just too much heat to the flange at once it warped but very little. Thanks
2002_Z28_Six_Speed
10-04-2015 01:34 PM
blown02408
10-01-2015 01:06 AM
lxcoupe
09-25-2015 12:36 PM
