285/70R17 on a 1500 Silverado?
Has anyone put 285/70R17's on a 1500 Crew Cab Silverado? IF so, I was curious how many turn did you have to turn up the torsion bars and what were the results? Positive or negative?
Probably (at this point) going to run a Raceline Deepstar 6 w 4.5 backspacing, but I'm not a fan of having my wheels stick out from my fenders. I'd rather use my stock wheels.
Piss Pumps for Sale
Location: Moncton, New Brunswick, Canada, The True North Strong and Free!
1 Post
you would be amazed at the size of tires you can fit with stock rims, or rims that are the same size with the same back spaceing, theres a guy on gmfs running 37s with ford keys on stock rims no other type of lift barely any trimming. But yeah you should be able to fit 285's with a mild crank if any at all
Easiest way to forget about rubbing is to find OEM replacement 17" rims...or 18's, 20's, whatever suits you. GM makes some pretty snazzy rims that last forever. If you want a different color, the 5-spoke GM 17x8's look amazing powder coated black.
