305/55/20 Nitto Terra Grapplers on 8" wide wheel?
Does anyone have a set of 305/55/20 tires mounted on an 8" wide rim?...and if so what's your opinion on the setup?
I've got a set of 20x8 wheels that I'd like to run that that size tire, but the suggested rim width is 9.0-(9.5)-10.0 according to Nitto. Just wondering if I could get away with running them on my 20x8s.
Registered User
well i use to work at discount tire so thats what i saw alot of but it only happened to tires with 50,000 plus miles and you'll prolly wear out those tires before that
Need More N2O Mod
they will work, the side wall will balloon a little more. you will probably have to play with the air pressure some so you can figure out where the tread will be flat when rolling.
if this was a performance street tire i wouldn't recomend it.
gaps
10-15-2015 02:53 PM
