315 75R 16 w/ Stock Height
Thanks man, they look really good, there a little pricey though at 210 a tire from summit.
Summit will mount and balance them if you buy a wheel and tire package right?
We did an 06 Dmax crew cab.Stock rim with 315's.Wasn't 2 crazy doing it with the stock wheels,but anyway,we did a 2" rear lift block and a Cognito leveling kit.Front valance was trimmed and the inner fender.Looks pretty good actually.
Yes,In my opinion they are a bit skinny.Tire wear will be more likely reduced,especially in towing mode,that's why I wasn't 2 crazy of doing it.But that's the look that he was looking for.It was 315's BF All terrains.
285/75/16 on 16x8's - Had to trim part of the plastic liner behind the washer reservoir, that's all. I love my Terra Grapplers, but the MTZs should treat you well!
I was going to suggest the BFGoodridge All Terrain's in the 285/75/16's for your stock wheels or 16x8's. That is what I ran on my 00 ECSB Z71. And I deffinitely do some offroading. They lasted me 55000+ miles with going to the dunes every year at least three or four times, airing down and climbing the sand hills!!! Plus they are a good street tire when you have them at around 40psi. I usually run 45-50psi, but I tow a boat and a toy hauler with the truck too. I have currently went and got a set of 17x9's and 265/70/17's. They are a little bit smaller but only by one inch.
They also fit really well without trimming or anything with the front torsions cranked up to level!!!
