TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
33's on z71
Old 01-04-2009, 09:04 PM
  #21
Originally Posted by 20firebird02
Well I got em on and rubbing more than just the valance LOL. It's rubbing front and back on the wheel well but i'm gonna try and do some triming tomorrow if it's not to cold. Btw I also cranked the bars almost to max.
Stock keys, or Ford keys?
Old 01-04-2009, 09:37 PM
  #22
Stock
Old 01-05-2009, 02:12 AM
  #23
StrokerAce03's Avatar
Originally Posted by SynergyV8
I will also give you the opportunity to edit your post, afterward I will then edit my quote of your post to reflect your changes.
Answer me this: If you max the stock torsion bar keys out to a spring rate of 400lb/in, for example, and crank the Ford re-indexed keys to the same spring rate of 400lb/in, which setup will ride the roughest? Hint: It is a trick question.
Nobody ever said anything about loading both keys to the same spring height; obviously they would ride the same. The difference is that the Ford keys at the same spring rate will provide more lift.
You don't like Ford keys; awesome, we get it. I am standing by what I said earlier and just providing a possible alternative; not starting a pissing match with a newbie.
Old 01-05-2009, 02:28 AM
  #24
12 Second Club
Mighty Whitey's Avatar
spring rate is relative to the sin angle of the lower a-arm. IIRC..
it doesn't matter what key you have, the angle of the a-arm dictates the spring rate and the lift. nothing else. one key is not going to put more spring weight on the bar at the same a-arm angle, compared to another key.
Old 01-05-2009, 04:16 PM
  #25
silveradol33's Avatar
werd. I havent seen one post from this dude that isnt starting a fight or talking **** about someones work or truck.
Dear newb- please do not respond to this, cause I will not argue with you.
Old 01-05-2009, 07:46 PM
  #26
A healthy crank (either stock keys or Ford keys if the stocks won't crank it up enough, common on '99+ trucks) is plenty to run 33x12.5x17s on stock wheels, possibly even 17x8s w/ 4.5" of BS depending on how much trimming one is willing to do (inner liner and valence). Hell, I'm running tires that are 32.8"x12.2" or so on a slightly lowered Z71 w/ no probs.
Old 01-06-2009, 07:38 PM
  #27
MonteCarlo31's Avatar
Leveled with factory keys. 295/70R17 Nitto Terra Grapplers.
Old 01-06-2009, 08:11 PM
  #28
05z71's Avatar
Ford keys(not maxxed), AAL out back 33x12.50x17 for shitzngiggles
Old 01-18-2009, 03:55 PM
  #29
11 Second Club
rel3rd's Avatar
Thumbs up
I just added the RC leveling kit on my 02 Z71 along with some new 285/75/16's on stock rims. I didn't "need" to raise it any, since there was zero rub at any point, but for the price of the leveling kit, complete with 4 new shocks, I couldn't beat it. Ride is not much rougher than stock IMHO.
Old 01-24-2009, 09:19 PM
  #30
That looks good. Did you get the complete kit(3 in blocks included) or just the keys?
Quick Reply: 33's on z71
