TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
39.5x18x15 super swampers on a 15x10 rim
Old 02-05-2007, 09:46 PM
Import Moderator
beastmode's Avatar
Originally Posted by StrokerAce03
A 39.5" tire is gonna be Hell on those 2wd front parts. You'd need at least 4.88 gears; and if you plan on using it very often you might want to look into changing the rear end to a 14 bolt with outers redrilled to a 5 lug to match your front.
ya i think a def upgrade to a 14 bolt is required. for the front i dont know if you would even consider but i would suggest a SFA swap, its not that hard. they actually make a kit that sells the shackles then all you need is the front springs and a old dana 44 and a tcase (sounds like alot but def worth the swap im sure)
Old 02-06-2007, 12:29 AM
whitesmokels1's Avatar
It's basically just going to be for looks and never really see any offroading. Do street miles put that much stress on it that the spindles can't handle that size tire?
Old 02-06-2007, 05:42 AM
Import Moderator
beastmode's Avatar
if you dont plan on wheelin it that much you should be ok, i know a guy whos runnin 39s on a K5 with the stock 10 bolt. As far as the front wit the spindles goes i wouldnt really know bout that, never had any experience, i couldnt see why it wouldnt hold up though if your not slamming the hell outta it all day every weekend
Old 02-06-2007, 09:43 AM
PMCSPIDER's Avatar
It's a 1997 2wd Chevy 1/2 ton 350/auto 5 lug. 12" custom lift
re-gear the ****** or convert it to a 5spd. You will blow your tenasmission with in 72 hours if you run tires over 35" with that tranny. I had a 1994 2500 4x4 and ran 36's and the mf-er blew three times beofre i re-geared it and converted it to 5spd
Old 02-06-2007, 09:44 AM
PMCSPIDER's Avatar
that model GM truck's auto trans is down right awfull, i hated mine.
Old 02-07-2007, 05:28 PM
Need More N2O Mod
mwalls54's Avatar
You might want to consider upgrading to 3/4 and 1 ton front end parts. most of the obs were swapable. If not your ball joints wont last long at all.
01-18-2016 06:33 PM
00loudchevy
12-03-2015 05:54 PM
wretched73
10-28-2015 09:21 PM
whitelazer
09-22-2015 09:38 PM
Quick Reply: 39.5x18x15 super swampers on a 15x10 rim
