4" suspension lift vs 6"
Originally Posted by bigblue09
hummmm wont 7 inches jsut make me super slow with my 4.3L??
A lift kit isn't going to slow you down much at all. It all depends on what size tires you run. If you run 35's, your truck is going to feel like you're driving a school bus. Hell even if you run 33's you're going to have the same problem.
Even if you re-gear it will certainly help, but in the end it's a 5000 pound truck with a v6 in it.
Don't cheap out on a lift. I've done it, others have done it too, you'll regret it. All the 6" kits I have seen use a spindle and larger coil springs which will make your truck ride like ****. Buy something like a 4" CST spindle lift or do step up to the 7" pro-comp/fabtech lift.
i know the tires will make me slower. but im not gonna leave the tires ive got on it right now. they are the biggest ones that will still fit but if there 7 inchesfurther away from the truck it will look bad with them. so id have to get new tires. making me slow again.
Where's the Beef?
If you want to lift it but don't do a lot of off-roading you should just get a body lift. This will give you the tire clearance without spending loads of money on a suspension kit you won't take advantage of.
If you do go off-roading then do the suspension lift, or both. I go mudding and climbing with my blazer with a 3" body and it works fine for the larger tires, but would love a suspension lift for more ground clearance.
