TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
4x4 problem
Old 01-11-2011, 04:26 PM
Most Hated's Avatar
Default 4x4 problem
When i put my truck in 4hi and floor it on a wet road or a dirt road it seems like just the back wheels are working so i put my truck on jack stands and put it on 4hi and the back wheels start turning then the front ones start rotating all together so it seems like its working but when i try it on the road it seems like if not what can it be ?
Old 01-11-2011, 04:27 PM
Most Hated's Avatar
I can even do a burn out in 4hi is that right?
Old 01-11-2011, 05:25 PM
2nd fastest 5.3 ECSB
trever1t's Avatar
I have no problem with that.
Old 01-11-2011, 05:39 PM
mhotrodscooter's Avatar
Actuator on the front diff is probably not working..
Old 01-11-2011, 05:48 PM
Most Hated's Avatar
By y does it work while on the jack stands
Most Hated's Avatar
When u have it in 4hi on the street will u spin the back tires or not
Old 01-11-2011, 05:58 PM
Front diff is turning. But passenger wheel is not locked in.. Or how ever that front diff works. Was both fronts spinning on the jack stands?
Old 01-11-2011, 06:17 PM
I have a gauge for that
Atomic's Avatar
Do you have the manual case or the autotrac one? I thought I just read about someone with a similar issue and the clutches in the auto case were shot.
Old 01-11-2011, 06:56 PM
pkozera's Avatar
Auto case i belive 246 is a turd left me stuck in some little stuff a that was the last time. And yes you should be able to stand on it in 4hi.
Old 01-11-2011, 07:48 PM
Most Hated's Avatar
I have the buttons on my left side and both tires were spinning on jack stands
Quick Reply: 4x4 problem
